vcIntEnumProperty
Typed property that holds a value with a description, limited by a pre-defined set of values.
Parent: vcProperty
Children: vcAvoidanceQuality, vcBackfaceMode, vcBitmapFileFormat, vcBitmapFormat, vcChartDataType, vcChartTileType, ... (see more)
vcAvoidanceQuality
vcBackfaceMode
vcBitmapFileFormat
vcBitmapFormat
vcChartDataType
vcChartTileType
vcChartType
vcClippingMode
vcCollisionTestMethod
vcConnectorTestLocation
vcConnectorType
vcEdgeShadingMode
vcEnumPropertyType
vcExpressionPropertyType
vcFocusModeDynamicSetting
vcJointAxis
vcJointServoType
vcJointType
vcLayoutItemType
vcLightType
vcLimitPropertyType
vcListPropertyType
vcMaterialDepthComparison
vcMaterialInheritance
vcMaterialOpacityType
vcMaterialRenderOrder
vcMatrixFormat
vcMenuTool
vcMessageBoxButton
vcMessageBoxImage
vcMessageBoxResult
vcMessageType
vcMoveType
vcNodeListEntryScope
vcNodeListEntryType
vcNodeSynchronizationType
vcNodeTreeScope
vcPackFolderState
vcPdfExportLevel
vcPropertyType
vcQuantityKind
vcReferencePropertyType
vcRenderShadingMode
vcSimNodeType
vcSimulationLevel
vcSimulationState
vcStepPropertyType
vcSweptVolumeDecompositionType
vcSweptVolumeMethod
vcVolumeDetectorTestMethod
AllowedValueslistRWGets or sets a list of allowed values for property. Each item is a tuple of (value, description).
TypevcEnumPropertyTypeRGets the type of the property.
ValueIntegerRWGets or sets the property value.
ValueDescriptionStringRGets the description of the current property value.
waitForobjectInteger OR None value,
waitForNotobjectInteger OR None value,
